Re: Farmall A - To Buy or Not to Buy?
Posted by athol carr on June 03, 2012 at 15:30:32 from (115.188.3.223):
In Reply to: Re: Farmall A - To Buy or Not to Buy? posted by SadFarmall on June 02, 2012 at 16:41:53:
Geelong made the GL-191 single furrow plough (12, 14 or 16 inch bottom), the GL195 two furrow plough (8 inch, special 9 and 10 inch), the GL-193 Spring tine cultivator, and the GL-194 Potato Digger (Spinner). All of these implements were pulled from the front cultivator mounts, the touch-control raised and lowered the implement and the other arm adjusted depth. The operators and parts manual I have a photocopy of is dated 4 April 1949.
