Re: Farmall M getting hot, need help!
Posted by S2710 on June 03, 2012 at 16:31:14 from (98.143.227.89):
In Reply to: Farmall M getting hot, need help! posted by BigTone on June 03, 2012 at 12:21:39:
My M was running hot and I looked in the radiator when it was running and I could see that the water pump was moving water. The fins on the radiator were clean but the tubes over half pluged. I drained all the water out and flushed it with a water hose. Then I filled the radiator and block with vineger. I ran the tractor raking hay and then came in and pulled the plugs and drained everything. Let it cool and flushed it with water and you should of seen the black stuff that came out. I then filled it with water and it still ran hot but the radiator was clean. Come to find out that the impellers on the water pump were about half gone and it was not pumping enought water to keep it cool. Replaced the water pump and now it runs like it should, and it also moves three times the water then it did before.
Bob
