Buck - If you are not a stickler for originality the cheapest is to replace the magneto kill switch with a DPDT toggle switch.
Wire one side of the switch to ground the magneto when the switch toggle is pointed down (your ignition "off" position). Wire the other side of the switch between the ammeter to the hourmeter so it supplies 12 volts to the hourmeter when the switch is "on".
Alternatively you can install an N.O. (normally open) pressure switch on the engine. Connect one side of the switch to the ammeter and the other to your hourmeter.
Key here is to get an N.O. pressure switch! Keep in mind most automotive oil pressure switches are N.C. (normally closed) - their contacts OPEN on sensing oil pressure.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
