IH 3514 with hydro 656
Posted by Brian Ke on June 03, 2012 at 22:10:57 from (148.63.183.226):
No forward but have reverse. The books I have point to forward check valve in the center section. The books tell me just about everything except how where to access the center relief/check valve and shuttle valve. The book tells me to remove the access panel but there is none on the tractor. One member told me to remove the pump on the right side and the valves are under there but I have no pump on the right side. I have a forward mounted pump that couples with the harmonic balancer. All my other pumps are internal. The book says to take of the bottom plate of the trasmission to access these which I am sure I don't want to do.
Can any one tell me where I can access the center section of the transmission so I can get at those check and relief valves? Please help as the repair books I paid $400 for don't tell you everything.
