Re: Farmall M getting hot, need help!
Posted by glennster on June 04, 2012 at 06:11:44 from (75.63.53.143):
In Reply to: Farmall M getting hot, need help! posted by BigTone on June 03, 2012 at 12:21:39:
i use "old" s method for cooling system flush. drain the radiator and fill it with straight vinegar. run it for 10 or 15 minutes, then let it set for a few days. the flush it with water till it runs clean. for cleaning the radiator fins, i like using castrol super clean. its a real strong degreaser. spray it on the fins, let it soak and rinse with a hose. i dont use a pressure washer, seen too many radiators get holes blown in em. last thing i would check is the distributor or mag timing advance. pull the cap, gently twist the rotor a little and see if it snaps back. if not the advance is prolly corroded up and stuck. if the timing is running retarded, it will heat up pretty quick.
