Re: wheel disc
Posted by sflem849 on June 04, 2012 at 06:44:56 from (69.197.84.39):
In Reply to: wheel disc posted by mkirsch on June 04, 2012 at 05:53:47:
I have a friend that did it. We put the new blades towards the inside and then moved the inside ones towards the outside. Ya know what I mean? That way it shouldn't ridge as bad. If the bades are super worn I would guess you need to replace them all.
