Re: IH 3388 hydraulic problem could use help
Posted by rufus80 on June 04, 2012 at 07:09:18 from (174.255.80.164):
In Reply to: IH 3388 hydraulic problem could use help posted by levi on June 04, 2012 at 06:36:52:
Shouldn't have to pull both levers at the same time. Should be able to independently control each fuction. I don't want to make you mad but are the hydraulic hoses hooked up correctly? The two from one cylinder going to one remote and the other two to the other remote. Also maybe something is plumbed wrong on the drill. Have you used this drill before on another tractor?
