Re: Am I missing a regulator????
Posted by SadFarmall on June 04, 2012 at 07:11:55 from (112.213.137.176):
In Reply to: Am I missing a regulator???? posted by dstates on June 03, 2012 at 19:43:58:
I would check (or have someone check, if you are unfamiliar) that the generator and regulator are good BEFORE you connect them up. Prevention is better than cure and it is cheaper clean a generator and regulator than to rebuild them after they have been burnt out. Looks like the regulator has been disconnected at some stage. Also, if you want to use the wiring on the tractor, be quite certain that it is not damaged and cannot create a direct short circuit to Earth / Ground.
SadFarmall
