That's a fairly common problem for a tractor that's been sitting a long time. A couple ways to break it free:
1 - Make sure the clutch linkage is working and properly adjusted. Put the tractor in 4th gear and block the clutch pedal down. Or have an assistant hold the clutch down. Use another tractor to pull your tractor forward 10 - 20 feet. Now move around behind and pull the tractor backward 10 - 20 feet. A few forward and back repetitions should cause the clutch to suddenly break free (you will know the instant it does!)
If the above doesn't work and your tractor has GOOD brakes, try this:
2 - Find a level, reasonably smooth/hard surface (a flat lane works well). Start the tractor in 1st gear, run the engine a bit above idle and "float shift" it up through the gears until you've got it rolling 4th. Now step on the clutch, open the throttle all the way and stand hard on the brakes. Generally the clutch will break free as the engine lugs down.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
