F-20 coolant pipe
Posted by Central Illinois on June 04, 2012 at 20:16:16 from (75.106.113.249):
The bottom coolant pipe that the sending unit threads into and bolts to the left side of the block has a lot of pitting on it. I am not really sure a new hose will seal to it. I have three thoughts on it. 1.just use silicone sealer and glue on the hose. 2.put on some JB Weld and sand it smooth. 3.braze it and grind it smooth. What are your thoughts? Thanks.
