Posted by Fullers Farmalls on June 05, 2012 at 13:21:26 from (72.77.77.162):
I wwent to work on my uncle tractor and the starter seems to not be engaging the flywheel. The starter will spin and move the bendex gear. When installed it seems as if it is just hitting the flywheel but not engaging the teeth. The teeth on both had some wear but not so much that it looked like they shouldn't mesh. Anyone have some ideas for help? Thanks in advance.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
