im gonna try and explain how i did it so bear with me.
i had the tractor on jack stands with the cast center's on the axles. put the floor jack under the axle and got the height right to slide the rim over without tearing up the paint. i used my tankers bar under the edge of the tire to 'slide' it towards the tractor. once i got it about where i wanted it i turned the cast center to get one of the holes as close to 12 o clock as i could. I then installed one wheel lock with the bolt and tightened it up. once it was on and tight i simply raised the floor jack up so the lock would seat on the 'rib' of the rim. once i got the lock at 12 o clock set i jacked it up some more just to allow the tire to come off the ground. at this point the tire will be able to swing back and forth allowing you to install the rest of the locks. i only finger tightened them til they were all on, they wrench toghtened them. managed to do it without scrating the rim all up. hopefully my process made sense. if not, when i go to put my rims on my 450LP in a few weeks i can take some pics of what i did
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
