If its a 8 spoke wheel one way is to install 2 clamps in adjoining holes. screw nut on the bolt 3/4 to a full nut. Turn wheel so clamps are at the top. Raise or lower tractor until the bevel used will go onto the clamps at top when the wheel is leaned in with 2 of the rim stops going in the clamps. Some rims have 2 and some 4. Next raise tractor until the bottom of the rim goes in enough to install the rest of the clamps. Raise tractor more if needed and tighten clamps trying to keep rim even all the way around until are are tight. Helps if someone else does the raising and lowering but I do it by myself most times.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
