Re: IH 684 add hydraulic rear remotes
Posted by JasonLC on June 05, 2012 at 17:18:27 from (108.206.17.40):
In Reply to: IH 684 add hydraulic rear remotes posted by JasonLC on June 04, 2012 at 19:54:23:
Thank you Jim. Very helpful. Do you know if I am correct to assume I can get pressure from the plug on the pump assembly? There is a hose connect directly beside it that looks to have the same size fitting as what would replace the plug?
In the diagram it says to connect to the elbow on #38. Can you tell me what #38 is? It doesn't look like the pump assembly I'm seeing. Thanks again!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
