If the carb is lean, and the fuel supply is OK, it needs to be cleaned and a wire run through every passage and orifice. Probably a restriction in the main jet. If turning out the load adjustment screw does not do it it is likely the carb. Thw connection between the intake manifold, and the exhaust manifold can crack, allowing exhaust into the intaks, EGR on the loose. It might be a long shot but worth knowing about. Jim
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
