Re: Getting too much air somewhere in the intake on the H...
Posted by mkirsch on June 06, 2012 at 05:36:51 from (64.80.110.74):
In Reply to: Getting too much air somewhere in the intake on the H... posted by Crazy Red Power in SE-WI on June 05, 2012 at 17:19:24:
An unlit propane or MAPP torch is perfectly fine for the test. All it has to be is a flammable gas. The engine fan will blow any residual gas away long before it can build up to be a fire risk.
I'd only worry if you were doing this under a hermetically sealed tarp, but then you'd probably die from carbon monoxide poisoning long before the gas built up to flammable levels.
