Re: Getting too much air somewhere in the intake on the H...
Posted by JRSutton on June 06, 2012 at 06:19:57 from (75.130.109.233):
In Reply to: Getting too much air somewhere in the intake on the H... posted by Crazy Red Power in SE-WI on June 05, 2012 at 17:19:24:
Might have missed something - but what makes you believe there's an air leak?
Generally speaking, any signs of an air leak can also point to gas blockage in the carb, and that's about 10 times more likely. Too much air is just another way of saying not enough gas.
Have you cleaned the carb thoroughly?
You can use thin wire to poke out all the passages. But if working on small engines/carbs is something you do more than once or twice every few years, I highly recommend an ultrasonic cleaner with a tank large enough to fit your carb.
Open up the carb, drop it in, comes out like new.
