Re: 300 and M carb interchange?
Posted by D Slater on June 06, 2012 at 07:18:41 from (184.15.2.205):
In Reply to: 300 and M carb interchange? posted by Zachary Hoyt on June 06, 2012 at 07:02:44:
Anything is possible but they have some different fuel and air metering systems. M can work complete but uses a bigger venturi and may lessen low end power. Choke shafts exit on different sides. Think I may have a extra bowl for your carb thats missing the choke shaft and some other parts you would need to install from yours if interested.
Also the M carb uses a off idle air slot system and some passages are sized accordingly. 300 gas carb has a different idle system in the throttle body and a different jet set up in the bowl and jet size and air passages are sized accordingly. With enough tunning it can work but don't think its worth the trouble for a stock tractor.
This post was edited by D Slater at 07:53:24 06/06/12.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
