Re: 300 and M carb interchange?
Posted by Andrew Z on June 06, 2012 at 08:16:30 from (72.10.122.33):
In Reply to: 300 and M carb interchange? posted by Zachary Hoyt on June 06, 2012 at 07:02:44:
Dave is right, unless you have major engine work you will loose power though the 'M' carb. Very common around here when guys throw a 'M' carb on a C152,C164,C169,C175 (H-350) and find out they have less bottom end etc. If your carb is cracked or inoperative then i would look for the right carb or take the guts out of yours and put them in a 'M' carb.
Andrew
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
