Re: It's the carb!
Posted by rhtx55 on June 06, 2012 at 18:57:40 from (207.119.56.137):
In Reply to: Getting too much air somewhere in the intake on the H... posted by Crazy Red Power in SE-WI on June 05, 2012 at 17:19:24:
Have you tried backing out the main jet adjustment a turn or two on the carb??
Screw it all the way in (gently) until it seats then back it out 3 & 1/2 turns, see if it will start & run without choking, go as many as 5 1/2 turns out, if that doesn't fix it, It's time to check the gas flow to the carb, the float level, and finally clean both jets in the carb, or just rebuild it.
