1466 hydraulic seat
Posted by Red Johnny2 on June 07, 2012 at 06:27:54 from (68.169.242.63):
Hi guys. My 1466 has a leaking hydraulic seat. Oil has been seeping out of the top of the cylinder where the rod comes out. I tore it apart and put a new o ring in the inside of the cylinder body. I did not replace the top wiper seal because it was $50 + and I was told it was really only for dirt and not for sealing oil. After a few weeks it started leaking again. The seat doesn"t leak down nearly as bad as before but oil is still coming down and leaking over SCV and rockshaft housing making a mess. Do you guys think it is worth trying that wiper seal or is it a worn rod. The rod/piston costs over $250! Any help or ideas to fix this without great expense would be appreciated.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
