Posted by D Slater on June 07, 2012 at 11:49:53 from (184.15.2.205):
In Reply to: Re: TA durability posted by sflem849 on June 07, 2012 at 07:52:11:
SMTA and into 100 series used non plated rollers and a different ramp before a change to plated rollers and matching ramp. Also rear planet carrier bearing was different and changed early on in 100 series. After change the later parts worked in early units but you wasn't supposed to mix plated and non plated parts. Rear carrier bearing was made thinner and a big shim, sheild or spacer washer used. Whatever one of the 3 you want to call it. The bearing center and outer race is slightly offset froom each other. Have to look close to see it. Would probably take most of my fingers to count the units I found with the bearing installed backwards. Only found one old unit in the last 10 or 15 years with the old thicker bearing in it. IH hasn't made the non plated parts for years. T/A clutches or t/a release bearings are going to wear out after a while. After so much time the lube in the release bearing is going to run out. T/A gear shafts and ramp roller parts seem to wear out the same or worse if the t/a is never used in the feild. Just my opinion but seems like the worst shape ones on average is from tractors with a non operating t/a clutch and run straight high for who knows how long.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
