Re: MD Magneto Help
Posted by CharlieNJ on June 07, 2012 at 17:01:24 from (76.117.68.151):
In Reply to: MD Magneto Help posted by IAtractorKid on June 07, 2012 at 16:31:20:
Did you use copper core wires? And, what is a "manifole switch"? Next I would check the ingnition points. If you pull off the cap and rotor, you will see a raised round area around the shaft with two screws, leave those screws alone. Split the magneto just below the cap by removing the three screws, two inside under the cap, and one outside. Then set the points to speck. Crank the engine to see if the points then spark.
Best Regards,
Charlie
