Posted by CNKS on June 07, 2012 at 17:38:47 from (216.144.104.128):
In Reply to: Farmall 450 lpg clutch posted by Farmall450lpg on June 07, 2012 at 12:07:09:
When IH started making the IPTO there is a shaft within a hollow shaft. One is splined to the pressure plate, the other to the disk. If you installed the disk and bolted the pressure plate to the flywheel before putting the tractor back together it is quite possible that you bent the clutch plate (don't ask me how I know, but the answer is obvious). Best to leave the plate loose and tighten the pressure plate after you put the front and rear together.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
