Re: 806D steering pump problems
Posted by Forge Farmer on June 07, 2012 at 17:54:30 from (72.72.230.210):
In Reply to: 806D steering pump problems posted by Jacob Yates on June 07, 2012 at 15:58:09:
It is more than likely the MCV hydraulic pump, located right behind the MCV valve body. Buzzinduzzin explained the operation well. From what I know about this setup, it can be hard on your T/A to continue running with low hydraulic pressure, so it may be good to get this pump changed as soon as you can.
