Hi RTR, An easy way to test a mechanical tach is take your cordless drill and a round file like the one that is used to sharpen a chain saw, put the file part in the drill chuck and the squared handle part into the tach drive, you may have to trim a little off the handle so it fit the tach drive properly. Start the drill slowly in one direction and if there is no tach movement then try the other direction. With the drill running in proper direction RPM needle should work and hours will roll on. On the 424 with BD-154 the tach gear drives off the top end of the oil pump shaft. I have had problems with that drive gear assembly. There are two bevel gears at 90 degree to each off. The end of the shaft of the driven gear wears and the gears no longer mesh. Check the tach drive cable first.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
