Posted by pete 23 on June 07, 2012 at 20:00:23 from (74.32.229.231):
In Reply to: Farmall 450 lpg clutch posted by Farmall450lpg on June 07, 2012 at 12:07:09:
Smoke out of the breather,well, it is either blow by past pistons, coolant vaporizing from oil(but you said oil level was ok) or a hot bearing. I would pull drain plug and check for foreign material. If engine seemed stiff you may just have put enough pressure on crankshaft thrust bearing during assembly to smoke it. These engine do no have a full flow oil filter so stuff goes through the whole lube system if any foreign material is floating around in there. You can pull filter and look for filings also. Sure hope not but can't come up with any other good options.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
