Hot alternator
Posted by Paul in SC on June 07, 2012 at 20:10:54 from (4.152.246.209):
Need opinion as to why newly replaced remanufactured 10 SI alternator is heating up. Alternator is on 1950 Farmall M and is wired as per Bob M"s diagram. Tractor has operated on 12 volt neg. ground for several years with no problems. Alternator was replaced due to non-charging of old unit. New unit runs hot to touch (too hot to hold hand on) after running 10 minutes at fast idle. Charging function is fine, showing charge on ammeter with a output of 13.8 to 14 volts. Just runs too hot to touch. Battery is in good shape. Any ideas?
