Re: 806D steering pump problems
Posted by Forge Farmer on June 08, 2012 at 06:23:39 from (72.72.248.38):
In Reply to: Re: 806D steering pump problems posted by Bob52 Martin on June 07, 2012 at 19:23:21:
No it does not. The MCV is a plate on the clutch housing on the left side of the tractor. Disconnect the linkages that connect to or cross it, then take the bolts off around the perimeter and it should come right off. The pump is bolted to the center of the plate with four bolts that come from the outside.
