Re: H belly pump again
Posted by Janicholson on June 08, 2012 at 06:59:01 from (96.24.99.126):
In Reply to: H belly pump again posted by ericy on June 07, 2012 at 21:22:21:
You can, but it has a pressure sensitive delay built in to its operation. That port is connected to internal valving. I think you would be happier (try it as you describe first) with a third ball valve Tee'd into the left front port. Do not use pluming valves. only hydraulic rated valves 1500 psi working pressure would be fine (though the tractor wount get to that pressure). Jim
