Posted by pete 23 on June 08, 2012 at 10:11:22 from (74.32.229.231):
In Reply to: 986 will not charge posted by Hager1070 on June 08, 2012 at 09:18:38:
Poor mans test of alternator. Put a screwdriver on the back side of the alternator, when engine is not running there should be no magnetic draw from screwdriver to alternator. Start engine, if the screwdriver sticks to alternator then it is charging. What you really need is a volt meter to check voltage before starting engine and after it is running. Battery voltage will be about 12 volts and then charging voltage should jump to above 13.6 to about 14.5. The two small wires on top of alternator, number two should be live with battery voltage at all times and the number one should read voltage when key is turned on. If either one does not have voltage your alternator will not charge. A simple two dollar test light works good for checking voltage to those two terminals. They have a habit of corroding or breaking off.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
