Re: Farmall 450 lp vaporizer
Posted by Hugh McKinney on June 08, 2012 at 19:36:58 from (75.106.0.39):
In Reply to: Farmall 450 lp vaporizer posted by Farmall450lpg on June 08, 2012 at 13:16:56:
Oh, I forgot to mention that Impco vaporizors can be had with about three different strength springs, which you replace by pulling the cover, I don't remember which side. For your 450, which is in the 50 horsepower range, you probably want to order the spring which is rated for about 40 hp ; when I used the original spring, the JD would barely run. Turns out the spring was rated for about 125 horsepower (that is, a very strong spring). Have fun with it!
