Posted by Janicholson on June 09, 2012 at 15:51:27 from (96.24.99.126):
In Reply to: Still 464 issues posted by Jay Snyder on June 09, 2012 at 13:44:43:
Running for 50 seconds. allows you to make the following experiment. It will place certainty in the diagnosis. Take a used spark plug wire (any type will do) use a utility knife to cut a wedge out of the insulation and notch the conductor so that it has a 1/8" gap. Connect this in place of the coil wire. This evening when it gets dark (or inside with covered windows) have someone start the tractor, and watch the spark. If the spark stops when the tractor does, it is ignition. If it continues strongly, the fuel delivery is at fault. If it is fuel, i imagine it is the float needle and seet. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
