Posted by Bob M on June 09, 2012 at 16:56:55 from (69.207.87.163):
In Reply to: 450 coil posted by P and R Pete on June 09, 2012 at 16:24:12:
A coil running too hot to touch says you've got 6 volt coil being fed 12 volts!
Wiring a ballast resistor in series between the ignition switch and the coil primary will solve the problem. Or replace the coil with a 12 volt coil (it will be marked "no external ballast resistor required" or similar....)
Incidentally a properly operating coil will become only a bit warmer than the metal distributor housing. Ie. it will be cooler than nearby engine surfaces.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
