Re: B Farmall steering U joint
Posted by 60 acre hillside on June 10, 2012 at 03:49:01 from (67.142.170.22):
In Reply to: Re: B Farmall steering U joint posted by Vern on June 09, 2012 at 21:14:17:
Vern, we are in the IHC room right now. You are in the JD or the AC room. All Farmall "B"s had an universal joint. the same joint used on a AC "WD"
