1568 trans light update
Posted by David Saville on September 28, 2000 at 08:31:55 from (142.165.111.241):
When I attempted to adjust the TA dump valve as per instructions I found that it had locked in the open position. The linkage seems to be free enough. Is the problem likely mechanical interfence or low pressure inside? Once the valve was reset the tractor worked well with the light out but I suspect it will hang up again and I would like to solve the problem. Thanks
Post A Followup
: Re: 1568 trans light update
