Re: farmall h gears
Posted by Wardner on June 10, 2012 at 09:51:41 from (4.154.251.252):
In Reply to: Re: farmall h gears posted by Wardner on June 10, 2012 at 09:36:55:
You can't use W-4 ring and pinion gears as they will speed up all gears. You might find that parts out of something like a 504 might fit or could be modified to work. That "3rd gear slower than 1st" is too weird to contemplate though. Probably thousands of dollars to make.
You could make something like a SHTA using 300. 330, 340, 350, 460, 504, 606 rear end and TA.
