If you go back and read the entire string TV and others talked about NI making brackets to mount the pickers on most tractor models. Some indicated that the biggest difference between tractors was the axel brackets with different size brackets needed for different IH models. The 656 had a relatively small frame being the decedent of the "M". The 706 was a larger frame and had thicker axel housings and the same brackets will not work. If you post a request in the Want Ads you might be able to pick up a set of correct brackets for your 706.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
