Re: amp gauge reading
Posted by Bob M on June 10, 2012 at 12:40:44 from (74.67.151.46):
In Reply to: amp gauge reading posted by BigTone on June 10, 2012 at 11:02:27:
If the battery partially discharged (like immediately after cranking) the ammeter will indicate 15 - 20 amps charge. As the battery becomes charged it will taper to 2 - 3 amps and stay there. This assumes the engine is running at full RPM - charge rates will be less at lower speeds.
Incidentally you may notice the ammeter hand "dancing" somewhat when the battery is full - this is completely normal.
