Re: Farmall M missing when it gets hot
Posted by WV Farmall on June 10, 2012 at 14:45:04 from (75.104.157.204):
In Reply to: Farmall M missing when it gets hot posted by WV Farmall on June 08, 2012 at 17:02:17:
Carb is clean and in good condition. I put new kit in carb. Also put new points and condenser in distributor. Tractor will run if you pull the choke while it is missing. If you shut tractor off for five minutes and let it cool it will run fine for about half hour and then starts missing again. Still open for suggestions!!!
