Re: Grandpa's H Has Spark Now, but Tank is Full of Crud
Posted by dstates on June 10, 2012 at 14:47:17 from (173.27.246.62):
In Reply to: Grandpa's H Has Spark Now, but Tank is Full of Crud posted by dstates on June 09, 2012 at 20:24:00:
I got my temporary solution figured out. I had drained the tank yesterday and was able to just brush out 95% of the rust and sediment in the tank (the section I could get to anyway) and then I took my shop vac and sucked on the outlet of the tank while I blew compressed air into the tank. That did amazing things. Then I flushed a quart or so through the tank a couple times. I ended up with a fairly clean tank for now. I know I'll have to do more later, but it worked.
By the way, I got it started today!!!!! I couldn't keep it running without being busy with the choke so I have more questions. I'll start another topic later tonight when I have time. Thanks for all of the help!!
By the way, I like the picture of the screen at the sediment bowl inlet. That is the sort of "snorkel" I was thinking of earlier.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
