Re: New farmall wont stay charged after i shut it off?
Posted by El Toro on June 10, 2012 at 16:14:30 from (108.3.225.57):
In Reply to: New farmall wont stay charged after i shut it off? posted by rbooe05 on June 10, 2012 at 14:34:35:
When you have it running measure the charging voltage across the battery terminals with the engine at 1/2 throttle or better using a volt meter. Should see 14-14.5 volts across the terminals. I wouldn't complain about your oil pressure. The coolant will expand when the engine gets hot. Don't fill the radiator completely full to top of the fill neck. Hal
