Re: New farmall wont stay charged after i shut it off?
Posted by old on June 10, 2012 at 17:15:43 from (209.86.226.32):
In Reply to: Re: New farmall wont stay charged after i shut it off? posted by rbooe05 on June 10, 2012 at 17:09:39:
Pull the battery cables off and charge the battery. Then say after an hour of charging it take the charger off and check voltage on the battery. Then come back another hour later and see if the battery has gone down or stayed the same. If it stayed the same then most likely you have a problem with the alternator. But what alternator system do you have that has a V.R. wire up to it instead of the more common internal V.R. which most people use
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
