Re: Rebuilding 2000 Loader Cylinders
Posted by IaGary on June 10, 2012 at 18:58:50 from (108.160.229.48):
In Reply to: Rebuilding 2000 Loader Cylinders posted by David Goode on June 10, 2012 at 14:09:03:
David I have rebuilt many cylinders and always just tighten them as tight as I can with a 2 ft breaker bar and it will be fine. I usually stick something thru thr pin hole while tightening and it helps to have someone to hold that end.
One other tip when you push the piston back in the tube use lots of oil to get it started.
Gary
