Re: Farmall M missing when it gets hot
Posted by Redroundhead on June 10, 2012 at 19:57:54 from (70.9.85.144):
In Reply to: Farmall M missing when it gets hot posted by WV Farmall on June 08, 2012 at 17:02:17:
Are you running premium gas? The lower grade stuff will/can vaprorize in the carburetor, if the ambient temperature is high, and the engine is hot. This happens alot on small air cooled engines.
I would have said it was a weak condenser or coil, but if pulling the choke helps it stop missing, then it sound like a fuel metering issue.
Just my opinion. Best of luck!
