First question is are you sure you don't have too much oil in the trans. They don't take much, and it's easy to over fill them.
Pull the level plug near the left brake connection and make sure none comes out.
If the level's ok - I'm not 100% sure - but I believe there's an inernal "weep hole" of sorts in the housing that allows the gear oil to flow through and not accumulate.
Even though it wasn't that long ago that I rebuilt mine - for the life of me I can't remember exactly where it was, or what I'm thinking about! - I just remember being surprised to find a hole somewhere in there that was plugged with sludge.
I'd pull the drive off, clean it all out with kerosene, and check things out - or perhaps somebody here with a better memory can clarify - I could be way off.
The housing comes over very easily - just be sure to retain the thin spacers if there are any - (sort of like thin metal gaskets).
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
