Re: New farmall wont stay charged after i shut it off?
Posted by El Toro on June 11, 2012 at 12:14:51 from (108.3.225.57):
In Reply to: New farmall wont stay charged after i shut it off? posted by rbooe05 on June 10, 2012 at 14:34:35:
Charge your battery overnight using a trickle charge. Use a hydrometer to measure the specific gravity (acid) in each cell and compare the readings. Should see 1.270 readings or somewhere near that. If one reads 1.100 you have dead cell. If every cell has very good readings disconnect your battery ground and see if your battery will start the engine when the
ground cable is reconnected the following day. it starts ok you probably have a drain on the battery. You can disconnect the ground cable each time you're finished with the tractor or install a master switch between the ground cable and another short battery cable to where your battery is grounded. This will isolate your battery from being grounded and won't drained the battery. You need to turn on the switch when making a start and to shut it off when finished for the day. The military has used master switches for years on their vehicles. Hal
