Posted by wayne in mn on June 11, 2012 at 21:06:02 from (24.179.166.208):
In Reply to: serious carb cleaner posted by IndiRon on June 11, 2012 at 20:21:29:
Get a glass bead blaster and pressurized cans of brake cleaner. Carb cleaner leaves a residue behind so I prefer brake cleaner as the rinsing solvent. Lots of ventilation is advised and use compressed air to finish the job. There are several small passages so inspect carefully. I use a single strand of out of the multiple strands from a short piece of 14 gauge copper taillight wire; it will conform to bends in a passage and will not damage a brass jet internal opening. Other wire sizes may be needed. Study the carb and attempt to run wire through all openings; with a varnished carb it may be necessary to use a twist drill bit (hand operated) to open up the passage.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
