Re: 454 width
Posted by mkirsch on June 12, 2012 at 06:00:22 from (64.80.110.74):
In Reply to: 454 width posted by whiskers1949 on June 12, 2012 at 05:24:07:
Do you know if the wheels are dished in or dished out now? If they're dished in already, flipping them over will only make the tractor wider.
Looking at pictures, it's the typical stamped steel wheel center and separate rim held on by several loops welded to the rim. You get different widths through combinations of flipping the wheel centers, mounting the rims on the inside or the outside of the dish, and swapping the rims from one side to the other.
If the tractor is set at the widest possible width, there probably isn't enough clearance to simply flip the dish over. It will likely rub on the fender. You would instead have to move the loops to the inside of the wheel center, or swap the rims side-to-side. Either will gain you 2" per side.
Hopefully the tires aren't loaded. The job won't be too bad if all you have to deal with are the tires and rims. Bring the whole socket set, 3/4" drive if you've got it for the center lugs, 1/2" to deal with the loop bolts.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
