Posted by rustyfarmall on June 12, 2012 at 06:11:52 from (67.55.162.174):
In Reply to: 53 Super H posted by Al Moyer on June 12, 2012 at 06:03:12:
Serial number prefix for an H will be FBH. Serial number prefix for a Super H will be SH. Disc brakes are not an indicator as the last few '53 Hs also had disc brakes, and before that the Ausco-Lambert aftermarket disc brakes were available for the Hs. The shorter oil filter canister showed up somewhere around 1946 or 1947, so that is not an indicator either.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
